2003 Mitsubishi eclipse. When i push throttle to the floor to excelorate quickly it starts bogging and loses power. what could it be? it could be a number of things. the first to check would be to see
Car won't start, won't turn over, has new battery, plenty of gas, first time this happened. I think I need to reset the anti-theft devise, need some advise, thanks hey you may have to check you engine
i have an 03 eclipse spyder and there are times when the car starts for like 2 seconds then dies out just got a new battery one mechanic tells me i need a new alternator while the other tells me its ...
...2003 Mitsubishi eclipse gts automatic transmission. Stopped at a stop sign started to go then it just stopped going, engine still running and in gear but wasn't moving. Have a pressure test done on ...
2003 Mitsubishi eclipse. My car would start & run then it wouldn't start again.i would wait a while then it would start. I had to bang on the starter to get it started. I replaced the starter but ...
Question about 2003 Eclipse
...eclipse no fuel nor spark. I've changed timing belt,cam and crank sensor as well as the computer. Any tips guys? Lets start at the basics: is everything that needs it getting +12v? There's the MPI ...
2003 Mitsubishi Eclipse start the car while I will not go off You can't just turn off the security system , It is incorporated in every control module on the vehicle . The key has a transponder in the
2003 eclipse spyder gts 3.0L V-6. was driving fine, turned corner and it died.Now it wont start.Took throttle body off and smelled fuel. ticking noise when key is on. Make sure battery has a full ...
...2003 Mitsubishi eclipse 4G64 engine just dies while driving. I disconnect ground to batt then reconnect. Car starts right up? Then after so much time driving does it again? New spark plugs, coils all ...
2003 Mitsubishi Eclipse my starter will start car but will not disengage Two possible causes of the starter failing to disengage - either the starter is seizing internally or the solenoid is remaining
