...code for a 04 focus The only way you can get this is to contact the location from where the car was purchased. There is no way you can crack the code. whats the serial number on the side and i can ...
...Focus RADIO/ CD PIN Code required PLEASE !!! Hi, I was working with fuses in my Ford Focus and the RADIO/ CD player is now requesting a PIN Code. I would really appreciate it if someone could decode ...
...have a Ford Focus 2004 with problem code P0507 coming up. I was wondering what it is and how I could fix it. Thank you. idle control system RPM higher than expected. Try cleaning the air intake ...
!!!!!!!!! can someone please tell me the code for my ford focus 04 radio please?? the serial no. is m118283 im going out of my mind pleeeeeeeeeeeeeease!!!!!! try this site... http://www.radio-code.com
...focus 2004 and i cant find the meaning of that code. couldyou help me? lean trouble code needs a oxygen sensor (o2) p2195= Fuel is running too rich or too lean. Are you using e-85? try putting a tank ...
...2004 ford focus check engine light when on, what can I do? Take the car to Auto Zone or Advance Auto Parts. They have a code scanner that can tell you what the check engine light means. They do that ...
need radio code for ford focus 2004, serial # M309219, cheers The code should be 9117
Question about 2004 Focus
2004 ford focus not charging battery... new alternator and battery My neighbor has a 2004 ford focus that after changing the alternator twice and replacing the battery, still wiil not charge. She has ...
...2004 ford focus.but how do i fix it? Trouble codes .po135,po141,po147 Well all three codes are for a problem with the heater circuit for the O2 sensors. And since all three sensors are not going to ...
... He is the 2004 ford focus. And radio is 6000 CD RDS eon! Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Best ...
