NEC MobilePro P300 Pocket PC Logo
A
Anonymous Posted on Sep 15, 2005
JAVA Does the P300 support Java?
Anonymous
Level 3:
Master:
  • Master 903 Answers
  • Posted on Sep 15, 2005
Anonymous
Master
Level 3:
Master:
Answers
903
Questions
43
Helped
160405
Points
2651
P300 supports Insignia JAVA VM.
How do I enable java in win10
Acces the Java Control Panel:
you can find the Java Control Panel through the Windows Start menu.
  1. Launch the Windows Start menu
  2. Click on Programs (All Apps on Windows 10)
  3. Find the Java program folder
  4. Click Configure Java to launch the Java Control Panel
If you don't see the Java folder then assume Java is not installed o your computer, then go to https://www.java.com/fr/download/manual.jsp
  • In the Java Control Panel, click the Security tab.
  • Select the option Enable Java content in the browser.
  • Click Apply and then OK to confirm the changes.
  • Restart the browser to enable the changes.
Hope this help...
2helpful
2answers
PrintMaster 2011 Platinum <3.0.70> encountered
Hello, I had the same issue, I found this article http://support.encore.com/technicalsupport/kb.aspx?kb_id=1250&product_id=2643 It pretty much says that your regional setting is not set to English United States. Changing that will resolve the issue. Under Control Panel > Regional Settings.
2answers
Java won't load on my computer
id suggest that you uninstall java and delete the folder from the hard drive after you uninstall it from the computer, and then clean the registry of any instances of old keys associated to java,then redownload and reinstall java fresh,be sure its the right version for your Vista ( home,Bussniess) Hope this Helps Steve
1helpful
Additional s/w support
Support can be found on the NEC Computers website, by calling NEC at 1-800-632-4525, or by contacting some of our software partners at the following locations: HTTPMicrosoft: www.microsoft.com/mobile/pocketpc Insignia(Java VM): www.insignia.com/products/qa.asp Arcsoft(PhotoBase): www.arcsoft.com/support Westtek(ClearVue): www.westtek.com/support.htm Ruksun(Voice Messenger Force): www.ruksun.com/mobile_computing/windowsce/faq.html ZioSoft(ZioGolf): www.ziosoft.com/html/top/faq_ziogolf2.html Cicsosoft(Golfwits): www.golfwits.com/support/golfwits-faq.asp Packet Video(PV Player): www.pv.com/uMobilePro P300te/faq.asp
7answers
Type of JAVA
java.applet(PersonalJava only), java.awt and sub-packages, java.beansjava, iojava.lang and sub-packages, java.lang.reflect, java.math, java.net, java.rmi and sub-packages, java.security, java.sql, java.text
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Rommel Balcita
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
