Pioneer DEH-P390MP CD Player Logo
Posted on Aug 13, 2011
How do i set the clock on a deh p390mp - Pioneer DEH-P390MP CD Player
5 Related Answers
Anonymous
  • 709 Answers
  • Posted on Nov 24, 2007
SOURCE: I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Anonymous
  • 24 Answers
  • Posted on Feb 21, 2008
SOURCE: setting clock on my pioneer deh 1400
the radio must be turned off with the ignition key in the on position... then hold the function key for about 3 seconds if it doesnt have the function key try the audio or source button one of them will bring you to a menu, once in that menu use the func key to scroll though options until you see the clock flashing.. use the up down left right keys to adjust these different options...
Anonymous
  • 113 Answers
  • Posted on Apr 04, 2008
SOURCE: setting clock on pionerr deh-p3500
try www.pioneerusa.com you can download the manual for this model -----
Anonymous
  • Posted on Sep 23, 2008
Totally worked on my pioneer radio- ive been trying to figure out the time adjustment feature for months....thanks!
mikehumble
  • 124 Answers
  • Posted on Dec 27, 2008
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
Deh-p390mp not working
You might be able to find a faceplate on eBay.
Pioneer DEH-P390MP will not turn on
Check the fuses in your car and on the head unit first, and then check for 12 volts to the power wire and acc wires. Check your ground wire for an open line. If everything checks out, it may be time to invest in a new head unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
13helpful
How do i set the clock on my DEH-1700?
Toddakins05
To set the clock on the DEH-1700
1. Press SOURCE and hold unitl the unit turns off.
2. Press AUDIO and hold until clock appears in the display.
3. Press <- or -> to select the segment of the clock display you wish to set.
4. Press + or - to set the clock.
Note to cancel clock settings press BAND
Hope this helps
Issken
3helpful
Setting clock-Pioneer DEH P3800MP
here is the link to your manuals:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-P3800MP.Support
1 Use Function to select Clock. Clock appears in the display.
2 Push left or right to select the segment of the clock display you
wish to set. Pushing left or right will select one segment of the clock display: Hour—Minute As you select segments of the clock display the segment selected will blink.
3 Push up or down to set the clock. Pushing up will increase the selected hour or minute. Pushing down will decrease the selected hour or minute.
Cheers!
15helpful
4answers
Clock
To set the clock on the Panasonic DEH-1600 car stereo, follow these instructions:
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Setting the clock
You first need to leave the key on and then turn off the radio (hold down "source"). next, press the "func" key. This will take you to the main setup menu. Now, you can use the arrow keys to get to "clock adj" and use the up and down arrows to adjust your hours and minutes. You're now ready to press the "source" key one more time and turn the radio back on.
30helpful
2answers
Pioneer super tuner 3
For most Pioneer single CD players, you can set the clock using the following steps:
1. Press and hold the SOURCE button until the unit turns off.
2.Press and hold the FUNCTION button, until display pops up, then release.
(If you do not have a FUNCTION button, then push the AUDIO button)
3. Press the FUNCTION button again until the clock shows on the display.
4. Press the UP and DOWN buttons to adjust the hours.
5. Press the LEFT or RIGHT arrows to move to the minutes.
6.Press the UP and DOWN to adjust minutes.
7. When complete, press the SOURCE button to exit.
  • 1 year ago
1helpful
2answers
How to select differt folders in my mp3 cd fro pioneer player
Try going to the Pioneer website and find the DEH-p3900mp page. Click on the documents tab and click on owner's manual.
1helpful
2answers
Hi Elimo
Top Pioneer Car Audio & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
