SOURCE: hi there i need code for sky remote to pair up to
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
SOURCE: Need a code so that i can operate my LG tv. model
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
SOURCE: LG 42PG6010 sky code
this might work
0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
SOURCE: i need sky remote code for sharp tv model no lc-32sh7e
Hi there. I hope you will see this reply. I bought one of these TV's yesterday and I've got the code from my dad's website www.satcure.net
If your remote is Version 6 then you will be able to follow the help on the sky box under
Interactive
Customer service
Program Remote
Then follow the steps using code 1221
If you have a Revolution 8 remote then you will have an easier job but with a 3 digit code.
3 digit code is 253
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn
on the TV receiver
2. Press TV on the Sky Remote Control
3.
Hold down SELECT and the RED buttons together for approximately two
seconds, until the RED LED on the Sky remote blinks twice.
4.
Enter three digit code from list for the receiver (early versions now
flash twice).
5. Press select to enter code structure (the LED
will flash twice if a valid code has been entered).
6. Now press
the STDBY button and test other functions.
Hope this helps/works!
