HP PSC 1315 All-in-One Printer Logo
Posted on Aug 16, 2011
The status on my printer is offline. how do i get it to go online. i need to print school work for tomorrow.
5 Related Answers
FoYLe
  • Posted on May 07, 2008
SOURCE: blinking lights & offline-use printer offline
replace ink cartridge
A
Anonymous
  • Posted on May 30, 2008
hi! how can i align my printer cartridge?
Jigawatts
  • Posted on Dec 03, 2008
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Anonymous
  • 15 Answers
  • Posted on Dec 14, 2008
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Anonymous
  • Posted on Mar 02, 2009
SOURCE: how to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
