SOURCE: Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
SOURCE: HP f1905e tilt and Height adjustment
I figured it out! Just takes a phillips screwdriver and a 5/16" open end wrench to tighten up some nuts inside the plastic housing. The plastic housing doesn't come off with the screws, but has to be slightly pryed up to release the little plastic catches. Be careful though, you don't want to break the plastic tabs. It's ok to break maybe 1 because there are several to take up the slack. At first I thought it was the nuts that are 1/2" (there are two that are close to 2 springs. But that was just for the tilt forward and backward. Actually there are 4 nuts (5/16") that need to be tightened. Don't over tighten or it will not tilt at all. I took photos of the disassembled base. If you have skype, then skype me at "golfbob" chino hills, and I can send the pics or talk you through it. Good luck.
SOURCE: Can't drive monitor
Try moving the monitor down to a lower res. I would try 640 x 480 first and then go up from there. Also, some adustments may be required in displays for the second monitor....
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
SOURCE: Can't figure out height adjustments
You can download user manual and read all about it here: http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=913N
