One side of your ATB is damaged and needs to be repaired/replaced. Below will explain what this is and what it does.
The QUAIFE ATB differential is designed to prevent the complete loss of
drive that occurs with a conventional differential when one wheel slips.
Whilst requiring some torque in the slipping wheel, the QUAIFE unit is
progressive in action but never locks - controlled power is transmitted
to all the driving wheels. Ideally suited to high powered front wheel
drive systems, QUAIFE ATB differentials are also used in rear and four
wheel drive vehicles where optimum traction is required. Installation is
identical to the normal differential with bearing pre-loads and pinion
mesh being restored to the original manufacturers' settings. Servicing
of the unit is simple as all gear pinions are free fitting and normal
final drive lubrication oils are retained.
As engine power outputs increase ever further, the ability to utilize
this extra performance becomes more important. Wheel spin may look
spectacular, but such losses of traction waste time either from a
standing start or exiting a bend, whether driving on the road, circuit,
rally stage or drag strip. Fortunately, QUAIFE's patented Automatic
Torque Biasing (ATB) Helical *** differentialis an effective,
well-proven, low-cost solution.
