Toshiba Satellite Pro 4600 Notebook Logo
Posted on Aug 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How set bious - Toshiba Satellite Pro 4600 Notebook
Anonymous
Level 2:
Sniper:
  • Expert 72 Answers
  • Posted on Aug 31, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
72
Questions
0
Helped
9272
Points
228
Restart laptop then press delete 2 or 3 times. bios page will open if u need to set bios to install windows then change boot sequence.
Each time i try to enter biou setup i get the massage bious guardian enable, how do i disable this thanks
Look around in your BIOS for a tab that says "Security Settings" then look for the setting to enable or disabled BIOS Guard™
How to reset bious password
Have for look for the jumber or dip switch to clear the bios, or take the cmos battery out and then replace it.
here is a site which you can download software which could be helpful:
http://www.s2services.com/bioscmospasswordfreeware.htm
POWER ON FOR 1 SECOND THEN SHUT DOWN
it means u macine can not boot. there may be many reason. go bious and set it 1 hdd,2 od and save byf10. secon virous can do this hdd scan another computer, ram and smps is not working properly check it one by one changing. then u can solve u problem . (nepal)
Bious setup
You pretty much need to Reset the bios.
To do this follow the following steps.
Shut down the computer and unplug it
Open the computer case
Locate the CMOS battery this is a circular button batter about the size on a nickel and will have CR 2032 on it
While having contact with the metal case remove the battery for about 5 min 10 to be safe
Replace that battery and reconnect the power cord
reboot and Hopefully when you go in to bios there should be no password
Let me know if this helps if not there is another way that certain boards need but i find this the best and easiest way for most.
2answers
Change bious language japae to english
you will need to download a bios update for that model motherboard from a uk or us ibm support website
regards
Vasko from BG
u have remove bious battry for few mints your password is brack
1helpful
2answers
Unknown bios error error code 8280
did you update go to intel side update bious
Cmos setting wrong
Not enought info.
1. need the brand of computer
2.if you know the brand you will know what F key to hit when booting up to get into the bious like the delete key or F12, F10. It some times takes a few tryes hitting the key to get in.
3.from there you could set the defaults.
I hope this helps
skippkon
1helpful
2answers
Need to reset the bios password
my sat came with a password installed on it and i had to remove the cmos batt to reset the bios.it was located on the right side of the comp under the keyboad, covered by a black piece of tape.
HP Compaq ProLiant 1600 Server biouse problume
the proliant 1600 is old , not worth repairing or fixing.
get a new one , cheap , faster , better and with fast ethernet too.
good luck
Top Toshiba Computers & Internet Experts
Frank Fernandez
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
