Cell Phones Logo
Posted on Sep 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I download java for my huawei m835 phone?
Anonymous
Level 2:
Sniper:
  • Expert 72 Answers
  • Posted on Sep 05, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
72
Questions
0
Helped
9272
Points
228
You mean download java apps or games if this mobile phone support java visit mobango.com mobile9.com
Huawei m835 manual
Hi Mickie.
see if this link will help you out for your manual.
Huawei Cell Phones Huawei m835 manual Google Search
WEAR IS SIM CARD SLOT FOR HUAWEI M 835
1.Carefully push the SIM card out of the wallet-sized plastic card carrier.
2.Turn your Huawei M835 off.
3.Grasp the notch at the top of the back panel and pull away from the Huawei M835 to remove the back cover.
4.You'll see a notch at the top of the battery.Use it to lift the battery out of the Huawei M835.
5. Your SIM card has one corner missing.Slide the SIM card into the SIM slot so that the corners match.Ensure that the gold contacts are facing downwards.You will hear a click.
6. Reinstall the battery and back cover and then power up the Huawei M835
How to repair the charger port on a huawei m835 android
replace the motherboard thats the only way you can repair the charging port. its attached on to it not as a removable piece.
How to unbrick a android huawei835
This How To UNbrick your huawei m835 phone step by step.
To tell if your phone is bricked it should only show just the huawei logo or the android logo when you try turn it on and no key combination works to boot into recovery, if u can boot into recovery, dont use this guide.
1) Click This Link to download Huaweis Oringinal Software. ---->HUAWEI M835 - Huawei Device Co., Ltd..
a)Click on the software tab and select the first file there. It may or may not show an error but dont worry just refresh the page and the download will start.
2)When its done, open the M860V100R001C153B251SP03 folder (the folder you just downloaded).You should see another folder called dload and some instructions.If you dont understand what im saying then click the instructions in the folder.
3)Connect your SD card NOT your m835 phone into the computer.
4)Then drag the dload folder any were on the SD card.
5)When thats done take out your battery and put it back in.
6)Press and hold Volume Up + End Call + And The power button at the same time.(i know this sounds wrong but it works)
7)Its Gonna Update your firmware.
8)When its done Turn On your device and the screen that popped up when you first got your phone should appear.
9)Continue with that and BAM your phone is now UNbricked.
Please help me unlock my phone HUAWEI M835, FCC ID: QISM835
Try calling either #228 or i think its *228 and re-programming your phone, it will change the lock code to its default, he last 4 digits of your number without changing anything else
How do i master reset my m835 huawei metro pcs phone
WITH PHONE OFF PRESS THE VOLUME UP BUTTON AND GREEN CALL BUTTON AT THE SAME THEN PRESS AND RELEASE THE POWER BUTTON ONCE IT TURNS ON RESET MENU WILL POP UP
1helpful
My Huawei M835 is bricked
flash software your mobile.
1helpful
How to remove battery from huawei m835
To remove battery from Huawei m835,
Turn the back of the phone, remove the outer covering(casing),
put your hand in the space provided to lift the battery and the battery is out.
Sep 14, 2011 • Cell Phones
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
