Televison & Video Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need the code for the remote for tv lc-32sb24u
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Sep 12, 2011
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
Hello
Three digit setup codes for Sharp TV with universal remote control are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search Method
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
I need a remote code for my vizio universal remote in order to set it up with this LC-32SB24U
Hi
Setup codes for Shart TV with Vizio universal remote control are:
0093, 0688
OK.
No remote to my sharp tv LC-32SB24U need codes to program my remote...
I have a Sharp LC-32SB24U TV, I need the universal code for my universal remote.
Iam on remote lockout,how do i get back in ? also how do i turn off the close caption? the tv is a sharp lc-32sb24u
Unplug your TV for 30 seconds then plug it back in , remote should work after that. Press CC button on your remote until you'll see CC OFF.
2helpful
Sharp LC-32SB24U TV. Remote no longer functions.
Unplu the TV from the wall, wait for 30 sec. plug it back in.
3helpful
Lost access to control SHARP TV
Unplug your unit and plug it back in after 2 minutes. When you plug it back in, try to use the remote to turn it on and see what happens. Good luck to you
I need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
