Master
- Posted on Sep 16, 2011
Re: How do I program an apex ad 1110wm DVD player with a...
Programming a Device using Code Search:
- Manually turn ON your device (TV, VCR, Cable Box)
- Press and "HOLD"
CODE SEARCH
- Press and release the device button you want to set up (TV,
VCR, Cable Box) However, if you are using AUX for a device, press and release
AUX first and then the device button for the type of device to be programmed
(TV, VCR,DVDor Cable). The selected device button will flash once.
- Release CODE SEARCH.
- Press OFF/ON repeatedly until the device turns off (you
may have to press up to 100 times at a rate of once per second).
- Once the device turns off, press and release ENTER.
- With the device on, press
any other button. If the device responds, no further programming is required.
If the device does not respond, repeat steps 1-6.
