Brother MFC-990CW COLOR INK-JET MFC Ink Jet Printer Logo
Posted on Sep 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My problem is that my printer says i cant print because it says unable to print 6A
Level 3:
  • Master 17,130 Answers
  • Posted on Sep 17, 2011
Master
Level 3:
Answers
17130
Questions
0
Helped
3710726
Points
52372
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
