SOURCE: How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
SOURCE: willnotrecoil
Hello . First thing is remove the starter rope and check to see if the flywheel turn by hand . If turn by hand you have a bad recoil starter , if does not turn by hand the piston is seized . Remove the spark plug and put 2 or 3 drops of oil (2stroke mixing oil) on the spark plug hole and try to turn it again by hand . If still does not turn you have to replace the piston and maybe the cylinder .
Hope this help
SOURCE: weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
SOURCE: how do u change the impeller? on a model 2595 weedeater blower
how do I change the impeller on a barracuda 2595?
SOURCE: need a replacement impeller for Craftsman blower
toro impellar is the same thing...even same part#(1009068)
