Washing Machines Logo
kendall shaw Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting f35 error code - Washing Machines
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Sep 23, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14652161
Points
60866
F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub.
This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer.
With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced. If you are not completely confident in your technical ability to safely access and check these components, I recommend calling a service technician to diagnose and repair the washer.
Hope this helps.
1helpful
What does error F35 mean?
It helps to have FULL make and model in such questions, but here are a few ideas
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor.
Jun 4, 2011
F35 error code appears during cycle - iFixit
https://www.ifixit.com > Answers > View > F35+error+co...
About
Whirlpool duet washer f35 error code
https://all-errors.com > whirlpool-duet-washer-f35-error
The F35 error code in the Whirlpool washer indicates some problems with the water level pressure switch. This sensor is responsible for measuring the amount ...
Troubleshooting the F35 Sud Error Code in the Whirlpool Duet ...
https://www.youtube.com > watch
PREVIEW
12:49 Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam Washer · For more tech advice on ...
YouTube · SamuraiRepairman · Oct 5, 2013
5helpful
2answers
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
1helpful
2answers
Error code washing is delayed wil wash half the clothes
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
10helpful
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
9helpful
2answers
Model: wfw9500tw01 f35 error
2helpful
5answers
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
3helpful
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Top Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
