Computers & Internet Logo
Anonymous Posted on Oct 10, 2011
How do I enable java on my browser? - Acer Computers & Internet
Anonymous
Level 3:
  • Master 823 Answers
  • Posted on Oct 10, 2011
Anonymous
Master
Level 3:
Answers
823
Questions
0
Helped
244232
Points
2398
Open a browser on the internet, click on tools at the top left side of your screen. Slide down to manage add on's. Find Java and make sure its not disabled. Then go back to tools and click on it, slide down to internet options and click on it. Click the last tab at the top right and go through the choices until you see enable java and make sure it is checked. Then save and exit.
How do I enable java in win10
Acces the Java Control Panel:
you can find the Java Control Panel through the Windows Start menu.
  1. Launch the Windows Start menu
  2. Click on Programs (All Apps on Windows 10)
  3. Find the Java program folder
  4. Click Configure Java to launch the Java Control Panel
If you don't see the Java folder then assume Java is not installed o your computer, then go to https://www.java.com/fr/download/manual.jsp
  • In the Java Control Panel, click the Security tab.
  • Select the option Enable Java content in the browser.
  • Click Apply and then OK to confirm the changes.
  • Restart the browser to enable the changes.
Hope this help...
Says i don't have java
What browser are you using? Due to some security issues, some browsers will disable the Java plug-in. This is often the case for older versions of Java. Check java.com for patches.
Check if the plug-in is enabled. In Internet Explorer, click on the Gear in the menu bar and select Manage Add-ons (scroll down to check the Java plug-in). In Firefox, go to Tools > Add-ons. Then go to the Plug-ins section. For Chrome, navigate to chrome://plugins.
If you see that Java is disabled, click on Enable and then restart the browser.
I hope this helps.
(due to the security issues with Java, you should only have one browser with the plug-in enabled. Do most of your web activities in a browser with Java disabled.)
1helpful
How to enable. Javascript in my (browser)
If you have the java script add on downloaded for the browser go to the menu in the upper right corner
click tools then options then add on scroll down to java add on and click enable if all you see is disable then it is already enabled. If you don't have the add on you can go to your browsers addon download page search for it and download it or go to java.com and downlaod java and install it it should enable it then if not try the above after installing java.
Nov 21, 2011 • HP Cameras
1helpful
It said that my javascritf in my browser is disabled that why i cant open my facebook....i cant view my profile how to enable the javascrift? thankyou
Welcome to fix ya.
What browser are you using? Enabling the java scirpt depends on the browser you are using. If you need the java runtime environment software you can download it here http://java.com/en/download/index.jsp
Hope this helps
1helpful
2answers
How do i turn java script on on a windows 7 laptop
STEP 1: Check to see if Java is installed
1. Click the Start button, and choose Control Panel
2. In the window that opens look for an icon named Java.
- If you see the Java icon double-click it, go to the Update tab and click Update Now and follow the instructions.
- If you don't see the Java icon go to http://www.java.com and click Free Java Download and follow the instructions.
STEP 2: Enable Java in your browser
Internet Explorer
1. In Internet Explorer on the toolbar click Tools > Internet Options.
2. Click the Programs tab.
3. Click Manage add-ons.
4. Scroll down until you see add-ons named "Java". If they say they are disabled, click them and click the Enable button.
5. When you're done click Close, OK then close Internet Explorer.
Firefox
1. Open Firefox and go to Tools > Options.
2. Click the Content tab.
3. Ensure there are checkmarks next to Enable Javascript and Enable Java.
4. Click OK, then close Firefox.
STEP 3 (Optional)
If Java still isn't working:
1. Click the Start button, and choose Control Panel.
2. Double-click the Java icon.
3. Click the Advanced tab.
4. Click [+] next to Default Java for browsers.
5. Ensure your browser has a checkmark next to it.
6. Click OK.
Hi im not computer literate...so i dont understand my promblem ..i already have java for my pogo games i have tested it like it instructed and also pop ups and all seems to be ok but it still wont connect...
For a few recent years, Java was considered risky for exploit malware, so many browsers disable Java even if it is installed on your computer.
The newest releases of Java are generally recognized as safe... but you have to enable them in your browser:
The link shared in this message takes to you a page at java.com that explains how to enable Java in your browser.
How do enable Java in my web browser
2helpful
The yahoo games is not loading the applet why is that
JavaScript are fully enabled in your browser. Follow the steps below for your browser:
Netscape 4.XX or newer for Windows, Mac, or Linux
Click "Edit" in the menu bar, and then select "Preferences."
Click the word "Advanced" and put checks in the boxes next to "Enable Java" and "Enable JavaScript."
Internet Explorer 4.XX for Windows
Click "View" in the menu bar, and then select "Internet Options."
Click the "Security" tab.
For the Internet Zone, be sure that the Security level is set to "Medium" or below. (If you 've chosen to customize your Security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You'll want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Next, click the "Advanced" tab.
Scroll down until you see the subheading "Java VM."
Check the boxes next to "Java logging enabled" and "Java console enabled." (Note: If you've checked the box next to "Java JIT compiler enabled" and are experiencing freezing problems, uncheck that box.)
Internet Explorer 5.XX or 6.XX for Windows
Click "Tools" in the menu bar, and then select "Internet Options."
Click the "Security" tab. For the Internet zone, be sure that the Security level is set to "Medium" or below. (If you've chosen to customize your security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You'll want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Check the boxes next to "Java logging enabled" and "Java console enabled." (Note: If you checked the box next to "Java JIT compiler enabled" and are experiencing freezing problems, uncheck that box.)
Note to Windows XP users
By default, the Windows XP operating system comes with the Internet Explorer 6 browser without the Java Virtual Machine (JVM) installed, which is required to run Java programs such as Yahoo! Games.
If you install Windows XP over an existing installation of Windows that already has Internet Explorer with a JVM installed, then you should be able to play just fine.
At this time, Microsoft no longer provides a download of the JVM if you do not already have it installed. You're welcome to contact them for information on where to find and download this program.
However, you have the option to download Sun's Java plug-in by visiting
http://www.java.com/en/download/help/aut…
Sun is the creator of Java, and their plug-in will allow you to play Yahoo! Games.
Internet Explorer 4.5 or 5 for Macintosh OS 8-9
Select "Edit" from your menu bar and choose "Preferences..."
Then, click the "Java" bullet within the Web Browser section.
Make sure that the "Enable Java" box is checked.
Internet Explorer 5 for Macintosh OS X
Select "Preferences" from the "Explorer" menu.
Select "Java" from the left navigation bar.
Place a check-mark next to "Enable Java."
You may also want to clear your cache and restart your browser.
If you continue to have problems, double-check your computer's compatibility with Yahoo! Games. Source(s): Yahoo games help page
Oct 19, 2009 • Yahoo Mail
Cant get into yahoo canasta
Try clearing out your browser cache first.
Double-check that Java and JavaScript are fully enabled in your browser:
Click the "Security" tab. For the Internet zone, be sure that the Security level is set to "Medium" or below. (If you have chosen to customize your security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You will want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Scroll down until you see the sub heading "Java VM."
2answers
How i install js script software
Java-script is a scripting language interpreted by you browser and is not installed on you PC like compiled software. Java, which is a programming language is installed by downloading JRE for www.sun.com.
If you browser is not running Java-script while viewing web-page, (eg: youtube) that is in you browser options, you probably need to enable JS in you settings. google "enable javascript YourBrowserGoesHere".
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
