I just bought a used 880 and when running I see small "sparks" from the plate behind the fan. It looks like the spark you get when using a battery powered fly swatter. That is the best way to...
DO NOT RUN THE MACHINE WITH THE DEFECTIVE PLATE! The sparks indicate that the plate is either defective, wet, or dirty. You can try cleaning the plate, then inspecting it for flaws.
The plates (4" white ceramic squares with screen glued to center of each side) must be clean and inserted correctly.
1) Soak the plates in equal parts plain ammonia/water for 5 minutes. Scrub gently with a toothbrush or small veggie brush. Rinse well. Blow dry or air dry. DO NOT use a towel or paper to dry it off. Avoid touching the screen with your fingers.
2) Inspect the plate carefully for cracks, discoloration, broken wires, loose mucilage, burned areas, or visible dirt or bug parts (!). If the plate is flawed or corrupted, you need to order a new one from Vollara (formerly EcoQuest/Alpine) at 800-989-2299. Use #16618 for the referral number.
3) Clean the metal fingers with a cotton swab and alcohol.
4) Insert the plates firmly, making sure they go in on the tracks, and that the contact fingers rest firmly on the screen part.
The little flickering light is simply an indicator of power, and is normal.
Sorry that's jodee1939@hotmail.com
