Kenmore HE2 Plus Front Load Washer Logo
A
Anonymous Posted on Dec 02, 2011
F12 error code - Kenmore HE2 Plus Front Load Washer
  • Anonymous Dec 02, 2011
    Hello what is the model number of your washer? Thank you
    Rick
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Dec 02, 2011
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
623700
Points
5973
Also here is a list of He2 error codes http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
I think the error code you are actually getting maybe an F21 due to there is no listing for F12. use this kink to put the unit into diagnostics and run the diagnostic menu which will give you your exact error code as well. I await your reply
Thank you
Rick
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
F12 error code
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
5helpful
Hotpoint WF860 1600 spin machine keeps flashing F12. How can I solve it please???
Hi
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps
Also Error code F12 is indicating a communications error between cards; Error code F12 is indicating a communications error between cards, this can be caused by one of several things. A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is an electrical problem as opposed to a mechanical one.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
2helpful
Hotpoint ultima washing machine has error code f-12
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
here is a link to all hotpoint error codes:
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
If this helps please rate me
7helpful
I get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
3helpful
Hotpoint aquarius wd440 showing f12 error code how can i fix it
F12 - Communication error a thing to try is resetting the machine to do this turn machine off at plug for 5 mins then back on and start a cycle and see if it happens again. hope this helps.
7helpful
Kenmore HE2 Plus Front Load Washer; Error Code F12
Is this a model 110.47512601 HE2 Plus? If it is, I do not see an F12 error code listed. I have a tech sheet for an HE2 Plus, but I only see an F21 error code.
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. If you require further assistance in determining the source of the error, please let me know.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
53helpful
3answers
F12 Error
what is F12 error code on a siemans wxlp1400 and how do i cure the fault, cheers
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
