Computers & Internet Logo
roger Posted on Dec 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Password for guest access - Linksys Computers & Internet
Anonymous
Level 3:
  • Master 550 Answers
  • Posted on Dec 08, 2011
Anonymous
Master
Level 3:
Answers
550
Questions
Helped
422431
Points
1147
What is the model number of your router? If you have installed the Cisco connect on your main computer then you can find the password for the guest network on Cisco connect software.
You will need to heck the Cisco connect software to find password for the guest network
1helpful
2answers
2answers
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
2helpful
Password for guest Cisco connect
For me I am using my laptop and my laptop call Toshiba what can I do make my internet on for good cause it tell me that I have to enter password for Cisco quest access
Need password on wireless guest account
The possibilities are -some one might have changed it for you. If someone got your password or hacked it then they could get on your network and change the password on the wireless router. Or did the router get reset without your knowledge(has the non-guest access changed)? If you left the default log in to the router you might want to change it also, it makes it harder even if someone gets wifi access.
Guest access cisco connect
If you give your password out indiscriminately, someone could get into your router and change the configuration (password). Not sure if this pertains to your router. Try to configure the router again and close down guest access until you can get a handle on who you can trust.
2answers
The Box claims there is a Guest Access. I find no reference or settings within the Router Set up for this activity. How do I set up Guest Access?
Hi Norman,
For guest access:
You can allow guests to use your Internet connection without joining your personal network.
The network name and password for the guest network is located on the network information card found under the foot of your Router
A person using your guest network will be able to join without a password, but will be shown a login page when they attempt to surf the Web..
They will need to enter the guest password into this page to continue.
Hope this helps!
Please Rate if it did!
Thanks,
Gary
How to setup guest access wbr-2310
Login into your router and in the wireless section you can enable guest access. On some models you can have the guest mode access only the internet, and you can select whether you want to have a password for the guest mode or not.
Want to put lock on guest
Linksys E series routers can broadcast 2 wireless networks. First one is the main wireless network which is secured wireless network.
The second network is a guest network which will always show you unsecured.
It will never show you secured and you can not make it secured.
However it has a web based security.
Anyone can connect to the guest network but will not be able to access Internet without Guest access password.
In other words there is a security.
You can disable guest access also.
See more about Cisco Guest network access password
Top Linksys Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
