Frigidaire Affinity ATF7000E Front Load Washer Logo
AUDREY WATERS Posted on Dec 11, 2011
I GET ERROR CODE E31 - Frigidaire Affinity ATF7000E Front Load Washer
My bushnell v2 shows a e31 error can this be fixed?
Can you check that the new battery is an alkaline battery? If it is, and you are still getting the E31 error code, you will need to return your rangefinder to Bushnell to have it reprogrammed.
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. Non-alkaline batteries just don't generate enough current for the laser to operate properly.
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
E31 error code on electrolux washing machine
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
1helpful
E31
Hello Stephanie - If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
ERROR CODE E31
Hi and Welcome to Fixya!
E31 simply means - Waste Toner Reservoir Overflow Problem (when the total number of copies is more than 100K sheets). After E31 is displayed, 1000 sheets may be copied before shutdown.
Hope this helps!
Takasashi
4helpful
Error E31 on Bushnell V2
Good luck.
1helpful
Affinity dryer with a e31 error. What should i do?
I have the same problem . The store replaced it with a brand newnew unit - SAME E31 error code appears and there is no solution
1helpful
E31 error code
Did a little search and this is what I've found. http://www.fixed4free.com/answers.php?id=30722 Goodluck.
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
