Dishwashers Logo
A
Anonymous Posted on Jan 07, 2012
Why does the spray arm keeps falling off? - Smeg Dishwashers
john Stell
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 03, 2022
john Stell
Contributor
Level 1:
Answers
Questions
0
Helped
4758
Points
I've got the same problem here - i made a video of it too (https://youtu.be/SzlIP6iArvs) - I hope you can solve my problem. Thanks.
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on May 19, 2009
SOURCE: dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
Anonymous
  • Posted on Dec 29, 2009
SOURCE: Frigidaire dishwasher PLD2850RDC2
i DON'T KNOW IF THIS IS A SOLUTION OR NOT. My DW (same make and model) came off after being knocked off with an overly tall dish load. But, in addition, the 'nipple' gasket (looks like the nipple for a baby bottle, pretty much) was broken. I attahced it several times, same problem. I am going to replace the gasket. I think it might be the necessary part to fix the issue.
Anonymous
  • 56 Answers
  • Posted on Feb 08, 2010
SOURCE: upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Testimonial: "Wish one could buy just the clip and not the whole assembly, but it is not expensive."
Anonymous
  • 17 Answers
  • Posted on Oct 02, 2010
SOURCE: how do you put upper arm and upper wash spray arm
just call me on +263912639492, thta's easy.thank you.
Dr. Kelson
Anonymous
  • 43501 Answers
  • Posted on Mar 20, 2011
SOURCE: the spray arms keep falling
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Top Smeg Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
