No display on laptop error codes 2000-0413 and 200-0321
SOURCE: when i put the laptop on the screen would not
This is Hassan. The problem that you are experiencing is most likely the LCD cable not seated properly. Remove the AC power and the battery from the system. Press and hold the power button for 20 seconds to properly discharge the unit. Remove the hinge cover, and reset the LCD cable attachment.
Attach the AC power and power on the system. Hopefully the LCD display comes up. Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
SOURCE: I have no picture or image in mine laptop
hello there,
maybe inside the laptop a cable got loose.
you may want to take the laptop to a technician to repair it - else you can dissassemble the laptop yourself,and check if everything is connected. google for model and instructons how to repair it or come back on me if you're willing to do it yourself
Testimonial: "I followed the advice of Rocketman;now mine laptop is okey; Rocketman; thank you very much> trvboven "
SOURCE: 0334
That message indicates that you did not input during the diagnostic that you could see the test. If the system is running normally, then the error can be ignored.
