Texas Instruments TI-89 Calculator Logo
A
Anonymous Posted on Mar 06, 2012
Arcsin How can I graph the arcsin function on my graphing calculator?
Stevan Milanovic
Level 2:
Sergeant:
  • Texas Instru... Expert 267 Answers
  • Posted on Mar 07, 2012
Stevan Milanovic
Level 2:
Sergeant:
Answers
267
Questions
Helped
226283
Points
795
For this problem you have to type in Y editor y1=arc sin x.
See captured images
5 Related Answers
Anonymous
  • Posted on Mar 11, 2008
SOURCE: Graphing
Hi, you can try uninstalling the transformation app in your calculator. This does not really uninstall your application, it only prevents it from interfering with it. You should be able to graph multiple functions after that.
1) Go to APPS
2) Press Transfrm
3) Click Uninstall
A
Anonymous
  • Posted on Oct 17, 2008
SOURCE: My calculator will only graph one graph at a time.
gp to apps, then transform, and then select uninstall
Anonymous
  • 69 Answers
  • Posted on May 11, 2009
SOURCE: How do I graph parabolas?
Parabolas are forms of the base equation X^2. So press the [Y=] key, and then type in the variation of x squared that you want
Anonymous
  • 13 Answers
  • Posted on Jun 16, 2009
SOURCE: My Graphing calculator has no x or y axis. Its all Blank.
Press the 2nd Button then the ZOOM button. Make sure that AxesOn is highlighted. If not, move your cursor down until you on AxesOn and press ENTER.
If AxesOn is highlighted, then it is probably your window. Press ZOOM, then 6.
Anonymous
  • Posted on Jul 15, 2009
SOURCE: my graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
2answers
How do I graph x<-3 on the calculator?
First you must use a graphing calculator.
Most graphing calculators graph functions, i.e. relations of the form y=f(x).
Some graphing calculators are able to graph equations (not necessarily functions). On one of these calculators your draw the vertical line x=-3, then you shade to the left of the point x=-3. That gives you the real line from infinity up to but not including x=-3.
Generally, people do not need calculators to find the solutions to inequalities in just one variable.
When I try to graph it says argument error
Your function is not correctly defined. If graph is function y=f(x), variable must be x; if graph is polar, variable must be theta, and if graph is parametric, variable must be t. This does not cover all possible cases. Check the graph type and the definition of the function.
"Undefined" as answer to an inverse sine calculation
I suspect that you are confusing things a bit.
The inverse sine, called the arcsine is a function defined in the closed interval [-1,1]. And so is the inverse cosine. Any value outside this interval will give you a non-real result (meaning a complex one).
There are no limitations on the domain of definition of the inverse hyperbolic sine or sinh^-1
If your input value is allowed to be complex, the arcsine function gives a complex value. See the screen capture
Domain error when I try to graph trigonometric functions
Possible: Inverse trigonometric functions have limited domains. For arcsine and arccosine it is between -1 and 1.
1helpful
Graphing ellipse
This is not a graphing calculator. Besides, most graphing calculators are able to graph functions, and conics are not functions. You need a utility that graphs conics. The Casio FX-9750G and others have a conics utility. On the TI83/84 Plus you can download an application that draws them.
How to graph polar equations
Your calculator does not have graphing capabilities. On a graphing calculator you would first select the graph type 1. function y= f(x), 2. parametric x=x(t), y=y(t), 3.polar r=function(theta).
I try to graph an absolute value on my Ti 89 and I put the inequality in right but when I go to graph it my calculator says undefined variable.
If you want to graph the absolute value of a function, feed the function to the absolute value ie graph y= abs(f(x)). The calculator will take care of it. See screen captures where I draw the function y1=x^3-5x^2-3 and y2='x^3-5x^2-3'. On the first graph the function is represented and on the second the function and its absolute value.
The calculator knows how to calculate the absolute value of an expression. The name of the command is abs(
How do I get more than one graph to graph? The calculator is stopping me from turning more than one graph on.
After entering the first function to graph press the down arrow and when the cursor blinks after Y2 type in the second function you wish to graph. After you finished entering multiple functions make sure the graph setting under the window button are set correctly so every function will be visible at the interval you set. After that you hit Graph and you should see your graphs being plotted.
I hope it helps.
1helpful
2answers
How do I clear things left in the stat plot window?
To clean the slate so to speak, just reset the RAM.
  1. Press [2nd][+] to access the (MEM)ory management function
  2. Press [7:Reset]
  3. Press [1:All Ram]
  4. Press [2:Reset]
  5. Press [CLEAR] to erase the "RAM cleared" Message
Calc
Top Texas Instruments Office Equipment & Supplies Experts
Rommel Balcita
Paul Bade
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
