Heating & Cooling Logo
Posted on Dec 01, 2017
E3 Error Code
I have a Soleus HM5-15R-32 that is giving an E3 error code. I let the heater sit unplugged for about 30 minutes, plugged it back in and it turned on an ran for several hours at 68F on the low setting then shut down with the E3 error code. The heater is only a month old.
Thanks,
Suzy
  • Anonymous Dec 04, 2008
    I get the same error, but I'm using it for A/C.
5 Related Answers
Anonymous
  • Posted on Sep 24, 2007
SOURCE: GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
MARLON KELLER
  • 111 Answers
  • Posted on Jun 13, 2008
SOURCE: LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Anonymous
  • 351 Answers
  • Posted on May 08, 2009
SOURCE: CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
Anonymous
  • 83 Answers
  • Posted on Jul 14, 2009
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Aug 23, 2009
SOURCE: Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Top Soleus Heating & Cooling Experts
Sudeep Chatterjee
Sudeep Chatterjee
Paul Carew
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
