Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
Posted on Jul 16, 2017
My dishwasher does not drain at the end of the cycle
My dishwasher Bosch SHE44C02UC does not drain out the water at the end. I've checked the drain line and it is ok. I checked the impeller and it is clean. I checked the "flipper" next to the impeller and it is good. I have it on a work bench. I added water to the tub. I activated the pump and it pumped out the water. I did it a second time and it still worked. Why is there water left in the tub.
5 Related Answers
Anonymous
  • Posted on Jan 11, 2009
SOURCE: Bosch SHU9925UC Dishwasher Stuck in Initial Drain Cycle
OK Bosch Dw fans.........here is the fix if your SHX dishwasher is stuck on the drain cycle. This may save you a couple hundred bucks.......so listen up. There is a tendency for the very small float switch to STICK in the ON position, which will cause the drain motor to continuously run......and DISallow any other function to work. DISCONNECT POWER. Did I mention to disconnect power? Take off the front base cover....2 torx screws. Remove the other 2 torx screws in the metal clips that fasten the top of the DW to the underside of your countertop. NOW...carefull slide your DW out. You may have to disconnect your water and elec supply if you do not have enough slack to pull it out. Once the DW is out of the cabinet, remove the shiny metal cover on the LEFT side by removing a single torx screw. You will now see a small plastic assembly with a red plastic piece that moves up and down as it rides on a small red styrofoam float. This up and down movement engages a small white plastic switch visible with 3 wires coming out of it. You can carefully UNSNAP this switch out of its mount, and pull the 3 wire plug off of it. THere is a small square blue plastic tab that is supposed to easily slide in and out of the switch. If it is stuck IN, you can sometimes tap the switch and the blue tab will pop out, which is what it is supposed to do without tapping it. You can carefully with a knife blade separate the case on this switch and note the way it comes apart. Clean out any micro debris out of the small channels that the blue tab ride up and down in. Then set it in the channel while holding up the small switch tab that rides on it and see if it slides up and down without sticking! I like to take a piece of wax paper and rub in on the channel and blue tap to provide some lube for the switch to slide easily on. Now, put the switch back on and manually move the red plastic assembly up and down while you are watching the blue tab. The tab should ride up and down with the red assy. If not, buy a new switch. Google the # on the switch and order one. If the tab slides up and down, put things together in reverse order and give it a try. Hope it works for you. This should take you an hour give or take. Take the $200 you just saved and have a night out on me. ........so even though these German Appliances have a good name because of past reliability, the american tendency to value engineer them with plastic parts to reduce costs and increase profit.........just cost you an hour of your time. Will we ever learn.? ......if it ain't broke, value engineer it until it only lasts through the warranty period so you can then collect service and parts blood money from your fellow american.
Anonymous
  • 116 Answers
  • Posted on Mar 11, 2007
SOURCE: Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Anonymous
  • Posted on Jul 18, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Anonymous
  • 205 Answers
  • Posted on Jul 21, 2009
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Anonymous
  • Posted on Jul 09, 2010
SOURCE: Dishwasher: BOSCH SHE43 - pump keeps draining
have the same problem...dishwasher drain pump keeps running and cycle wil not start. Dishwasher is about 1 year old. Help appreciated!
Top Bosch Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
