Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
Posted on Nov 12, 2008
Broken fan switch
Model CVG2420
  • Anonymous Nov 28, 2008
    what is the solution?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
208
Points
0
Whats the solution?
Jenn air downdraft fan 2e speed doesn't work
Probably the switch or a burnt out resistor.
Mar 18, 2014 • Cooktops
Replacing fan switch jenn aire D156
I have a Radio Shack 3-in-one remote control 15-302 and I need codes for Dinex TV..it says it is 4 numbers
The blower won't turn off on the grill side of the stove. I changed the switch but the blower stays on.
Since I don't know your model number, I will have to give you deneric advise. Some fans have a thermostat that will activate the fan when certain temperatures are met. If yours is like that, then the thermostat could be the cause.
1helpful
2answers
Cooktop Model, Maytag JED8430ADB. When I tried to replace the Fan Control Knob, I accidently pushed the Fan Switch and Knob into the compartment below. How do I get the switch & knob back?
Hello, Thank You for using FixYa. I will be helping you today.You have to lift the unit up from the counter use some boards across the counter to support it and remove the screws from around the unit under the glass lip. On some units there are screws under the vent grille also. After removing the screws lift the whole top off.Thats all you have to do.
Thank You and please rate my answer if it was helpful..
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Fan switch broken .Need tofind out how to replace the switch
take the grill off
turn the power off
you will see a screw direct center where the fan switch is
remove it
pull the whole plastic piece up you will be able to replace it.
let me know how it goes
Jenn air fan comes on with rear burners (elec) can I disable?
Perhaps, but sound safety says no. This generates a lot of heat in an enclosed space; the fan may be a nuisance but it is needed to keep the unit from getting too hot. Hope this helps!
Need a wiring diagram for the burner switch for model c-206b-c
Hello vijay_sin204,
Here is a link for you to view a wiring diagram as well as exploded view with parts list of your cook top. I hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
1helpful
Cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
4answers
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Top Jenn-Air Cooktops Experts
gerbee gomez
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
