LOL, well you start by removing the rubber bumpers that are on the plastic strip that is around the screen. Once you remove them you will see screws that you will need to take off. One the screws are off you can remove the plastic strip by sliding your fingers inside where the scree meets the plastic strip and pry it alose from the hinges. Afterwards you start removing screws that hold the lcd screen in place. There will be screws on the sides, top and bottom. Once all the screws are removed lift the lcd screen out or you can tilt the lcd forward a little as if you are closing it and the screen will move forward into your hand. All you do next is remove the cable from the back of the lcd screen and remove the cable at the bottom of the lcd screen that goes into the lcd inverter. Now you're ready to put the new screen in.
