SanDisk Sansa e260 MP3 Player Logo
Katt Noway Posted on Nov 15, 2006
"refresh database failed" how do I do a database refresh?
I have a problem with my sandisk e260...it says "refresh dtabase failed" I can't play song on it. It worked the first time, but then I tried to put more songs on it and that message showed up. How do I refresh the database?
  • Katt Noway Jan 06, 2007
    e-mail sansa...go to the website...inform them and they will reply. You will need to reformat your sansa. Once they reply back you, they will redirect you to a location on their website for a program to download to fix your sansa. Ofter I did that, it worked perfectly fine after that.
  • Katt Noway Mar 05, 2007
    This is the comment I revieved back from SanDisk
    __________
    If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it.
    Please change the device mode to MSC (Mass Storage Class) if your device in MTP (Media Transfer Protocol). To do this, from your player. Go to Menu > Settings > USB >
    The two options are MSC and AUTO DETECT (MTP): select MSC
    Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player.
    If not already done, please also update the firmware from this link:
    http://www.sandisk.com/Retail/Default.as...
    __________
    Hope this helps ya...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 06, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6745
Points
I have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Anonymous
Level 1:
  • Posted on Jan 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6745
Points
Try adding/removing microSD card it should refresh database
A
Anonymous
Um, I turn mine on and it says "Refresh Database" and slowly fades to black? What do I do?
A
Anonymous
Get the latest firmware
Anonymous
Level 1:
  • Posted on Mar 05, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6745
Points
My computer died while sending files to player, and now the refresh database screen appears on the player and it do nothing. I hope that removing battery will help. I can't even connect it to a computer in normal mode, it connects in recovery mode, but I can't update firmware then. I will write if something will help.
  • Anonymous Mar 05, 2007
A
Anonymous
I called the technical support. He told me the following steps: 1. turn the player off. 2. switch the "hold" button ( on top) to see the orange area 3. keep pushing the "Rec" button and connect the player to the computer in the same time. 4. the player will come to recovery mode. 5.detach the connection with computer 6. release "Rec" button and let it turn off automatically 7. turn on the player. It should be fine. But for my case, it doesn't work. Then he asked me to remove the back cover of the player to take out the battery for one hour. Then repeat the same procedures. I am doing so now. Hope it works.
Anonymous
Level 1:
  • Posted on Mar 12, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6745
Points
Dear users of this player, this problem appers to be the common one. This is the best and easiest solution of the problem : 1.Change USB mode to MSC( in Menu->Settings->USB mode->MSC in order to make your player work as a flash drive. 2.Connect it to the computer using the cord. 3.Right click on the appeaed Sansa e260 in drives list and choose FORMAT( FAT32 ). Don't be afraid that system files will be deleted, they are protected. This may help:)
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
