The camcorder is simply informing you that the Custom Preset 2 settings are in effect. Refer to the "Using the Custom Preset" section of the manual (page 68 in my copy). If you need a manual you may download a copy here.
SOURCE: Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
SOURCE: get eject tape message
I had this problem this weekend with an Elura 65, where the camera would not accept a tape. If you inserted a tape, it would beep a few times, the LCD screen would flash "REMOVE CASSETTE TAPE" and then it would spit the tape out. I had the camcorder stored in a ziplock bag in a cool / dry cabinet in our spare bedroom. None of the previous solutions worked for me (clean the heads, take out the batteries, remove power for 20 minutes, remove the memory card, etc).
What worked for me:
I left the main battery in, installed the small memory battery, installed the SD memory card and plugged in the power cord. I left the camera out (close to my computer), which is upstairs in my house- in a 70-75 degree Farenheight environment - for 24hrs. After 24hrs of sitting out and being plugged in to power, I suspect everything came to an ambient temperature and the camera worked fine. (you might try up to 48hrs of being warm)
I suspect that most people's cameras are having this trouble when the internal parts of the camera are not all warmed up so the camera will reject a tape because something is NOT functioning properly when cold.
If you look at the timing of these postings, you will see that most people are posting issues in the cold winter months. I won't buy another Canon Camcorder, but am appeased at it coming back to life long enough for me to download my information to my computer.
If you call the service support for Canon (which I did), they will ask you for your serial number, model, date of purchase, name, email address & mailing address. They will ask you to mial your camera along with the printed information above and detail your problem. It will take 7-10 business days for someone to contact you via email or phone.
Good luck with your camcorders!
cjammin - Cedar Park, Tx
SOURCE: Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
