Kenmore Elite 45986 Front Load Washer Logo
Robert Posted on May 01, 2012
Code LOC Will not turn on and says LOC
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
396
Points
Take three screws out of bottom panel have something to catch water and loosen two inch plug on bottom right slowly and catch about four gallons of water then clean change and whatever else is in compartment
How to how to unlock car radio 2008 Chevy Impala
Requirements
The theft lock radio must be in "LOC" mode.
Procedure:
1. Turn the ignition ON (The radio should display "LOC")
2. Hold down the Radio Presets 2 and 3 buttons for six seconds
3. The radio display changes from LOC to a three-digit number. Write this number down. You now have fifteen seconds to complete the next step.
4. Press the AM/FM button
5. The radio display changes to another three-digit number. Write this number to the right of the first one.
6. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
7. Call 1-800-537-5140
8. Press 1 then # (pound). You'll hear "Invalid Code, try again"
9. Press 139010 or 106010 or 206010 or 202107 then # (pound). You will be asked to enter your four or six digit code followed by *
10. Enter the number from STEP 6 then *
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to "SEC". Your radio is now "un-locked" and usable.
Dealership Codes
  • 139010
  • 106010
  • 206010
  • 202107
Troubleshooting
If you fail to enter the correct code eight times, the radio goes into INOP mode. You have to wait an hour with the ignnition on before the radio returns to LOC mode.
2helpful
I need the radio unlock code for a 98 grand prix
The following instructions will allow you to reset any GM (General Motors), Cadillac, Oldsmobile, Buick, Pontiac theft lock radio.
Requirements: the theft lock radio must be in "LOC" mode.
Procedure:
If you fail to enter the correct code eight times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode.
Hope this helps; keep in touch.
3helpful
My audio system is stuck in the 'loc' position. We didn't have a code so we can't unlock it. Suburban
How to Reset GM Theft lock Radio's
Article Disclaimer: This article is meant to be used by Delco Radio owners to reset there radios. In no way is it meant to be used for any unethical or unlawful ways.
Purpose
Requirements
Procedure:
9. Press 139010 or 106010 or 206010 or 202107 then # (pound). "it's really *<star>lol"
Dealership Codes
* 139010
* 106010
* 206010
* 202107
Troubleshooting
Thank you for using fixya and good luck
20helpful
2answers
Default code to unlock factory radio in a 2000
Purpose
Requirements
Procedure:
Dealership Codes
139010
106010
206010
202107
Troubleshooting
To Read the original article or read similar articles please visit kingbain.com/how-to/unlock-gm-theftlock-radio-s
Good luck (remmeber comment and rated this).
GE JKS05 loc Getting "loc" on the display screen. Can't unlock it. Tried turning circuit breaker of for up to 15 mins, but didn't help.
HI. This is a control lock out feature. This is a child safety feature, and not a oven fault. Simply, Press the Nine and zero pad, simultaneously, until the "LOC" code disappears.
This will correct the issue.
I need radio code for a chevy s10
Re: Radio Locked The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction in your Owner’s manual. Use the code from STEP 11 instead of your personal code
1helpful
2answers
Radio stuck in "LOC"
you have locked the radio and will need to leave the ignition on for one hour to let it reset, then push 5&6 to get the code.  Radio should display --- and will let you try 3 codes then loc will display for one hour.  Just turn on the ign with engine off and pull parking brake to kill the drl lights.  And don't leve it unattended ;)   the code will need to be called in to obtain the unlock code.
1helpful
Radio stuck on loc
power radio on then hold 2 and 3
Radio
Good Day,
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
07. Call 1 800 537 5140 08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Owner’s manual. Use the code from STEP 11 instead of your personal code.
I hope this helps
This came from:
http://answers.yahoo.com/question/index?qid=20070717061922AA7xMG3
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
