Computers & Internet Logo
James Dodd Posted on May 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ram memory I have a SOLTEK SL-K 890 Pro-929 motherboard with 512 mb of current on board memory. What is the maxium amount of Ram memory that this board will support?. What kind of Ram chip set fits this board? Thanks AJ Please respond to 2064Smokey@gmail.com
Brian Sullivan
Level 3:
  • Soltek Master 27,725 Answers
  • Posted on May 14, 2012
Brian Sullivan
Soltek Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope it helps
5 Related Answers
Anonymous
  • 624 Answers
  • Posted on Jan 06, 2007
SOURCE: SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Anonymous
  • Posted on Jan 29, 2008
SOURCE: Drivers for Soltek Motherboard
necesito los drives de la placa madre soltek SL-85DRV5
ha graceria la ayuda
Ronald Hostetler
  • 5 Answers
  • Posted on Mar 06, 2008
SOURCE: EPoX EP-8K7A+ motherboard - memory problems
The first thing i would suggest it so make sure you have the latest Flash Bios installed on your motherboard.
Just for giggles you could try to reverse the dimms just to make sure one of them isnt bad.
Another thing to try is to take a qtip with alcohol, unplug the computer and attempt to clean the contacts that house the dimm. If it has been in use for years there may be dust buildup.
Anonymous
  • 183 Answers
  • Posted on May 16, 2008
SOURCE: Soltek SL-65KV2 Motherboard Drivers
ok,
i am giving you 1 link for your motherboard driver,download & use it
as you finished this article reading you wil get your driver at your drive,
DLL
http://www.driver-central.com/download-11056-4607.html
Anonymous
  • 167 Answers
  • Posted on Mar 25, 2009
SOURCE: Loss of Ram in D102G intel Board
hello, you just have a shared memory with the on-board ati graphics, if it's on- board graphic card it shares the system memory-most are adjustable through the system bios-in 64,128,256 settings. and if you put more memory, in most cases it will automatic-raise the memory size of the graphics memory. i hope this helps you, all the best. if you need further assistance reply. don't forget to rate this solution.
Top Soltek Computers & Internet Experts
Paul Bade
Anonymous
Anonymous
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
