Finisher communication error. User intervention is required to Power Off/On the machine; service is required if problem persists. Print and Copy services are disabled.
SOURCE: service required error 0001002d
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
SOURCE: canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
SOURCE: User intervention required
at your printer options or your canon pixma, check your ports setting in his properties...
SOURCE: user intervention required
check the connection and restart the printer .........
if not working means reinstall the printer driver ..........
SOURCE: My Canon Pixma MP150 printer LCD shows error
It is problem any hardware is not work properly.If you are a technician please service your printer properly.Clean all surface, blowing it.when you show E2 press black or color key
