Exercise & Fitness Logo
aditi Posted on May 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 91 - Exercise & Fitness
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on May 27, 2012
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4176552
Points
34435
I do not know what is the error code 91, but you must read the instruction manual section troubleshooting. Run the software calibration for diagnose and troubleshooting. If you do not have go to www. iconservice.com or www.fitness.manualsonline.com
However this codes can be relationed with 2 alternatives:
1) elevation motor 2) Main motor.
a) adjust the speed sensor, clean, and tight the wires connector.
b) measure the input voltage motor, if there are the motor need repair.
c) measure the output voltage board, for input voltage motor, if there are NOT, the board is faulty.
SEE The block diagram. God bless you
Sony camcorder xdcam pdw-700 error codes 91-225
No matter what errors are present you will need the manufacturer to repair it, they do not supply repair info or parts to the public, only approved repair stations.
What does it mean when my Frigidaire professional series dishwasher has an error code of 91 and the China/Crystal setting light is illuminated?
Rod, Try unplugging or turning off breaker for ten minutes to reset. If this does not fix, you may want a good Tech. have a look, diagnose and estimate repair.
Code E91 could be User Interface to Main Control Board communication error. Communication problem. Check the wiring between the Main Control Board and the User Interface Board. Wiring bad, correct wiring problem. Wiring good, replace the User Interface Board. If the problem is not corrected, replace the Main Control Board.
What Is Error Code 91 On Frigidaire Dishwasher Professional Series
http://www.manualsonline.com/support/frigidaire/dishwasher/error-code-91-5195801
http://forum.appliancepartspros.com/washer-repair/476079-error-code-91-a.html
http://www.elektro-ivicic.cz/data/user-content/soubory%20ke%20stazeni/Electrolux-chyby.pdf
1helpful
4answers
Why is code 91 on screen?
About 1,080,000 results (0.79 seconds) Search Results
    Chevy Cruze error code 91 - Fixya
    www.fixya.com/cars/t18378173-chevy_cruze_error_code_91
    Jun 2, 2013 - Chevy Cruze error code 91 What is Error code 91? It appeared ... Ya i know that what is error code 91 it is that ur car key is not there & if shows error code35 then ur car remote key cell losing his power exchange with that cell & ur car is ok. Posted on ... SOURCE: chevrolet cruze 2.0 LT 163cv error. If im not ...
    Warning: Cruze Start/Stop button & Immobiliser Design Flaw ...
    gearheads.in > Forum > Indian Automotive Scene > Chevrolet > Cruze
    Apr 16, 2013 - 10 posts - ‎7 authors
    4kms later I realised that I had the Cruze key with me in my pocket ... If the key is outside the car and you try to start it, it throws a Code 91 Error ...
    Cruze error code ' Chevy Cruze Blog : Chevrolet Cruze Blog
    www.cruzeblog.com/cruze-error-code/
    Translate this page Mar 7, 2014 - Cruze Error Code Vehicle message 1 C
What does error code 90, 91 and 92.
if its a nsm jukebox the three error codes refer to title mech jam
4helpful
3answers
ya i know that what is error code 91 it is that ur car key is not there & if shows error code 35 then ur car remote key cell losing his power exchange with that cell & ur car is ok
Cyber shot DSC-W561 error code E:91:01 - how can reset normal condition?
Download the service manual from elektotanya.com and find the complete explanation to the error codes. This is a service center job.
5helpful
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
2helpful
2answers
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
4helpful
2answers
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
DSC W55 Error code E:91:01
Hi,  Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY.
  For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Top Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
