Ribbon breaking continuously is caused by 2 common problems. 1. The printhead is going down before OR after the card has passed through. You would know this when you open your cover, and unlock you printhead, is the break before or after the card? Try printing the test page from the driver. That doesn't print "Edge to Edge" so if this is the problem, it should not break. 2. The print head heat settings are too high. If this is so, you can change this on the printers menu panel. I can explain more information, once I know your problem.
Hi ,
The problem with my fargo DTC 525 is:-
The Printing is not proper quality.There are patches on printed images.
Regards,
Umesh Sutar,
Tyco fire & security
m ribbon for my dtc 525 breaks firstly on the yellow ribbon, i cleaned the ribbon know it breaks on the blue. How can i fix this problem
failed to initialize Fargo DTC525 ID Card Printer
Everytime I print a card, the only coulour that is not aligned is yellow. I use a Fargo HDP5000. Pls assist..?!
