Computers & Internet Logo
Posted on Dec 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a runtime error 9 subscript out of range, when i try to open a program
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Dec 05, 2008
Anonymous
Expert
Level 2:
Answers
61
Questions
0
Helped
8035
Points
158
  1. Start the Visual Basic Editor (press ALT+F11).
  2. If Project Explorer is not visible, press CTRL+R to activate Project Explorer.
  3. Click to select the Visual Basic project that contains the module sheet that you want to copy.
  4. On the Tools menu, click References. Click to select the Microsoft Visual Basic for Applications Extensibility 5.3 check box, and then click OK.
  5. Click Module on the Insert menu.
  6. Type the following code into the module sheet: Sub CopyModule() Dim CodeLines As String Dim ModuleToCopy As VBComponent Dim NewModule As VBComponent ' Set a variable to the module to copy. ' Note: This assumes that the name of the module to copy is ' "module2". Replace "Module2" with the name of the module to copy. Set ModuleToCopy = _ Application.VBE.ActiveVBProject.VBComponents("module2") ' Get the Visual Basic code from the module. CodeLines = ModuleToCopy.CodeModule.Lines _ (1, ModuleToCopy.CodeModule.CountOfLines) ' Create a module sheet in another workbook. ' Note: You must refer to the name of the Visual Basic project. By ' default, the name of all new projects is "VBAProject". You may want ' to rename the project to which you are copying the contents of the ' module sheet. Set NewModule = Application.VBE.VBProjects("VBAProject") _ .VBComponents.Add(vbext_ct_StdModule) ' Add the Visual Basic code to the new module. NewModule.CodeModule.AddFromString CodeLines ' Rename the new module to the name of the previous module. NewModule.Name = ModuleToCopy.Name End Sub
  7. Run the CopyModule procedure.
Regards
Samson Ved
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
