My printer is saying their is a error code 1102 but the manual doesn't list the codes
If you get errors after refilling and then you clear the error!
And you still get errors occuring then this is a problem with the
cartridge.
1)The cartridges printhead may have burned out if it was run dry. (new cartridge is required)
2) No ink is coming out of the port hole! Try dabbing the bottom of the
cartridge on tissue. Ink should appear if not then use tissue with
Isopropyl alcohol and blot lightly until ink apppears.
3) If not ink appears then you may have an air bubble blocking the flow
of the ink. wrap cartridge tightly in plastic wrap holing in an up
right position whip downwards this will force air to the top of the
cartridge and open the port on the bottom. Remove wrap and try it out.
4) If the cartridge sat empty for a period of time before refilling you
are wasting your time. The ink is probably sitting at the top of the
cartridge and can not migrate to the bottom, in this case it may have
burned out.
In refilling of Lexmark cartridges:
Refill often and do not allow them to run dry. Running them while there
is not ink in the cartridge burns the print head out and the cartridge
will not work and you will get an error.
By refilling often the cartridge stays in good condition, you do not
run out of ink during a print job, and the cartridge will have a
prolonged life span.
2 things typically throw code 1102. Either your print head/cartridges are out of position, or your power cord/supply is not working properly. Check and redo both, then cycle the power and you should clear the error.
One of the leading brands of printers is Lexmark. This is an amazing printing device that is used by millions of users from across the world. But you might face certain technical difficulties while working with this printer. One of the major issues of this Lexmark Printer Error Code 1102. To those who are facing this complication, you don't need to worry anymore. Because fixing printer error code 1102 is an easy process and you can take help of a Lexmark printer support in USA & Canada.
Causes of Lexmark Printer Error Code 1102: -
1.If a user has built-up a wrong position of the printing cartridge.
2.If a user has incorrectly set the printhead on the printer.
3.If a printer power cord is not working in a proper way.
Easy Way to Solve Your Lexmark Printer Error 1102: -
If you are trying manually to solve this error from your printer then the given steps will help you to get an instant result. You need to follow each below mentioned step.
Lexmark Printer Customer Service: -
For quick and instant solutions related to any of your Lexmark printer problem, please get in touch with Lexmark Printer Customer Support technicians.for More Information Visit: How to Fix Lexmark Printer Error Code 1102 1 866 231 0111
Call Our Customer Service For Help and Support Call 1 8O5*465*751O Toll Free
24x7*''''''''''
