I unplugged my ps3 b4 cutting it off and when i cut it back on it said i had to restore my hardrive and there was an update and at the bottom it said will restart after update and after the update the screen just went blank...
SOURCE: PS3 cuts off during game play.
Hey, thanks that is very helpful, im pretty mechanicly inclined, so im gonna tackle myself, is there anyway you could give me a ruff walkthruogh of what to do to replace the compound and where i can locate some good stuff to use, dont have the cash right now to get fixed and just not playing is not an option, thanks a lot, really helpful, thejey
SOURCE: ps3 hardrive problem
If you're feeling more ambitious, replacing the hard drive might fix the problem. It's a bit of a gamble, since if it doesn't fix the problem, you're out the cost of an extra hard drive. But, if it does work, you've got some additional bragging rights, and the hard drives available today are up to four times as big as the current offerings by Sony; you can make your PlayStation 3 a 320 Gig model.
There is a small panel on one side (the bottom if you stand it vertically) that pulls off, and inside a smaller casing that unscrews to reveal an ordinary 2.5 inch, 5400 RPM, SATA laptop hard drive. Web sites such as CNet include video tutorials that can walk you through the process. If you've ever upgraded a laptop yourself, this is pretty similar.
I'm planning on doing this on my own PS3 as an "elective procedure." There's a way to back up the hard drive first, so you can transfer game saves, video downloads, and so forth. Unfortunately, this doesn't appear to be an option if you're experiencing hard drive failure.
I think this runs a good chance of fixing the problem, but it's not an absolute guarantee. But, if it does fix it, it could also give you a sizable upgrade.
SOURCE: ps3 system restore nightmare
all the files you need are on the system, you can access them by using the following method to the letter.
Be sure to folleow these instructions to the letter, you could damage your PS3
if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3
firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory
like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash
