Computers & Internet Logo
A
Anonymous Posted on Jul 18, 2012
I want block facebook on https using sonicwall tz 170
4 Related Answers
Anonymous
  • 42 Answers
  • Posted on Feb 07, 2010
SOURCE: i need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Anonymous
  • 1932 Answers
  • Posted on Sep 24, 2010
SOURCE: sonicwall tz 170 password
Password for you sonicawall tz170 is password
Thank You
Anonymous
  • 80 Answers
  • Posted on Jun 02, 2010
SOURCE: how to block https (to block facebook) in
You will need to use a third party firmware or update your current firmware on the firewall
Anonymous
  • Posted on May 26, 2011
SOURCE: Sir I have SonicWall pro 2040,
Just upgrade to the IPS (instrusion prevention subscription) for your 2040 and check Prevent ALL for HIGH, MEDIUM and LOW (LOW blocks Facebook like a champ). You'll find some other services blocked as well such as Terminal Services, but you can filter individual LOW priority attacks to allow those connections in (I recommend VPN for Terminal services anyway).
I actually was looking for a way to OPEN connections to Facebook while preventing LOW priority attacks and found your post.
-lt
www.thornedigital.com
Top SonicWALL Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Anonymous
Gopi Venkatesan
Gopi Venkatesan
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
