Mitsubishi WS-65819 TV Logo
Anonymous Posted on Aug 01, 2012
Power on problem
The TV doesn't power on. Suddenly i was watching tv and suddenly the tv was turning off, then i tried turning on (with the power button), and the image appeared one second, and was turning off inmediatly Now, when I push the power button, the tv try to power on, an image appear, and right away, the tv turning off.
  • Anonymous Aug 03, 2012
    Problem solved! There were a little humidity and corrosion over the chip, (maybe the microprocessor) Just a little of contact cleaner, and problem solved! Thanks everybody for your advice!
  • ernesto cuadra
    ernesto cuadra Aug 03, 2012
    o.k God bless you
ernesto cuadra
Level 3:
Top Expert:
  • Mitsubishi Master 12,223 Answers
  • Posted on Aug 01, 2012
ernesto cuadra
Mitsubishi Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4176552
Points
34435
1) test the outlet wall plug a desk lamp for to see if word, if does goto
1a) test the power cord
2) test the main switch for open or defective
3)go to the power supply see if the blown fuse replace or c.breaker reset.
4) if the problem persist, see for short in diode, transformer, filter, coil,rectifier.see the block diagram
God bless you
3 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
  • Posted on May 01, 2008
SOURCE: telivision dont want to power up.
You are experiencing the Mitsubishi Green Blinking Light of Death which is fixable.
All you need to do is replace the four 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors) which are inadequate for this tv. These capacitors are apparently undersized, in that they will eventually fail (usually after about 3 years) if and inevitably when there are voltage fluctuations in the circuit above 16 volts. It is then recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur.
If you are good with soldering and know how to work with electronics then this will be an easy fix otherwise I suggest getting someone to replace the capacitors that knows how to deal with them without getting an electrical shock. You can get the capacitors at any electronics store such as Radio Shack.
Good luck and please let me know if you have any further questions.
thanks
Anonymous
  • 1153 Answers
  • Posted on Sep 21, 2007
SOURCE: TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Anonymous
  • 21 Answers
  • Posted on Jan 20, 2010
SOURCE: Mitsubishi Diamond TV power went out TV wont turn back on.
the regular problem is the convergence kit,
Top Mitsubishi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
