Fuji FinePix S5200 / S5600 Digital Camera Logo
Andrei Machado Posted on Aug 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"Focus error" on
So, when I turn my camera on I can't take pictures anymore because I got the message "focus error". What could I do to solve this?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Fuji Master 102,366 Answers
  • Posted on Aug 13, 2012
Fuji Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10724326
Points
622696
5 Related Answers
Anonymous
  • Posted on Jan 22, 2008
SOURCE: fUJIFILM A 310
Hi
I had same thing. I took camera to bits and still didn't work. Then one day just before throwing it in the bin with batteries in and lens extended, I grabbed the outer ring (bigger part of lens near the body) and pulled it out a little further. I think there was a slight click then the red light turned green and everything was back to normal. Maybe I was lucky,but its worth a try because it definitely worked for me. Cheers John
Anonymous
  • Posted on Oct 29, 2008
SOURCE: I have FOCUS ERROR ON MY FUJIFILM FINEPIX s6500fd CAMERA
This is just a suggestion, as I am not an expert.A couple of years ago I had a problem with my older, Fuji Finepix camera related to the computer downloads/programming and I found Fujifinepix web site. I sent them an email and they responded and did not charge anything. Could try that..
david
  • 244 Answers
  • Posted on Jan 25, 2009
SOURCE: focus error
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
Anonymous
  • 5 Answers
  • Posted on Feb 21, 2009
SOURCE: focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at worldin1@gmail.com
david
  • 244 Answers
  • Posted on Aug 15, 2009
SOURCE: focus error on s5600 fuli help
The clip on the focus drive has detached itself from the motor thread ( or possibly broken )
There are no drive gears on this model, only a motor with a screw thread about half an inch long which the focus lens travels up and down on. This is attached to the drive thread by a small clip and a tension spring.
You will have to access you lens unit to acertain the problem.
My email is listed in "THE ONLY WAY I KNOW HOW.." in my tips and tricks section on my profile if you require any advice or help should you wish to effect a repair your self.
Top Fuji Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Rommel Balcita
Are you a Fuji Camera Expert? Answer questions, earn points and help others
