Dryers Logo
Posted on Aug 22, 2012
Westinghouse affinity dryer has error code E68
TRRIED TO RESET nd still wont work need new control panel where can i get one?
5 Related Answers
Anonymous
  • Posted on Sep 27, 2008
SOURCE: frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 18, 2009
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Anonymous
  • Posted on Mar 30, 2009
SOURCE: My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Anonymous
  • Posted on Jul 03, 2009
SOURCE: Frigidaire Affinity Front Load Electric Dryer
I have a totally unrelated solution. Remove your lint filter. Now remove the waffled plastic that covers the lint filter slot. Hint, its inside the dryer, and there's two screws holding it in. Be careful, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is either the temperature or moisture sensor, I bet. Don't drop the screws into the lint filter slot. If yours is like mine, you'll find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint, and reinstall. While you have it opened up, stick your vacuum's crevice tool down inside the lint filter slot and clean up all the lint in there as best you can. Problem solved. I think the build of of lint was shorting the two contacts, and this was screwing up the electronics.
Anonymous
  • 1531 Answers
  • Posted on Sep 17, 2009
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Top General Electric Dryers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
