Seagate FreeAgent® GoFlex? Black 1TB bundle with GoFlex Net Hard Drive Logo
Anonymous Posted on Aug 29, 2012
What is the solution to my problem? - Seagate FreeAgent® GoFlex? Black 1TB bundle with GoFlex Net Hard Drive
  • Anonymous Aug 29, 2012
    Please clarify?
Brian Sullivan
Level 3:
  • Seagate Master 27,725 Answers
  • Posted on Aug 30, 2012
Brian Sullivan
Seagate Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
You failed to provide a problem thats a problem in itself
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Top Seagate Computers & Internet Experts
Narseman
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
