SOURCE: Blue Screen of Death when running MIDI input to Lexicon Omega
I tried the above - works perfect!
Thanx lumps...
Thomas
SOURCE: My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
SOURCE: tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
SOURCE: cubase audio problem
the settings in the cubase le - devices - device setup are not set properly or the driver has been removed from the computer.
Id suggest you remove both the cubase le and the hardware device you use with it, then reinstall the cubase and your device. you may need to set the setting again in the device setup and it should work fine.
SOURCE: IDT high definition audio codec (code 10)
Try and install the "Modem" first restart and then wait if it ask for a driver in your audio.
