Frigidaire Affinity ATF7000E Front Load Washer Logo
lance telford Posted on Sep 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 32 - Frigidaire Affinity ATF7000E Front Load Washer
  • Official Brand Answer 4,342 Answers
  • Posted on Sep 20, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1495608
Points
5908
Hello Lance - Error code 32 for Frigidaire models means there is pressure sensor calibration problem. This will need to be checked and a repair performed by a technician since they must do the following: inspect the wiring between the pressure sensor and the main control board. Correct the defective wiring and/or replace the pressure sensor or main control board.
1helpful
Error code 32 21
Code 32 errors are nearly always caused by driver problems. Whether it is a misconfigured driver, a missing driver, or a corrupt driver, it is rather safe to assume that the problem is driver-related.
You need to most likely remove, then re-install the printer driver on your machine.
Good Luck!
Rich Lilja
Error code 32 in tally.. attempting to open files in tally
If you are facing a error code 32 so does not mean it is a specific reason of this error. If you have the NOD32 ESET antivirus. you can fix it by uninstalling the antivirus. Telly should work normally again after removing the antivirus..
Mac connection keeps timing out with error code 3253or code 32
on wifi? on certain web pages. try changing the channel of you wifi router. you may be getting interference
My display driver keeps reporting Code 32. I've tried various uninstalls and reinstalls and changed between multiple different graphics cards. All display drivers display error Code 32. what else can I...
Code 32 Errors are usual caused when the start type of Hardware Devices or Drivers is Disabled in the Registry, Roll Back the driver after rebooting You Computer, Or if you have restore Points Use that to restore the drivers
1helpful
I'm getting an error code 32.On a WS-55859
32 isnt a valid code for your model. Mitsubishi model WS55859 has only 5 possible codes they are 12, 21, 22, 23, and 24 Double check the code again and resond to this same post and i will assist you.
Engine check lamp light for fey seconds. Error code 32 is diplayed. Jeep cherokee 2.5td 1995.
Review the correct year for Error Code 32:
32 (1984 only) power loss/limited lamp or circuit
OR
32 EGR gases not working (1988) - check vacuum, valve
OR
32 (1990-92) computer didn’t see change in air/’fuel ratio when EGR activated - check valve, vacuum lines, and EGR electrical
Hope helped (remember rated this help).
Error 32 on br-s800U
I'm assuming your display reads "Er32 1" which is actually error code 321. This code simply means "Error in loading" and can be caused by many things such as an obstruction, a problem with the loading carriage, or even failure of the machine to enter one of the function modes. On these machines, the error code only describes the "effect", and you have to determine the cause.
Error code COF 32
i need service manual for the printer minolta di602
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
