Pentax X70 Digital Camera Logo
A
Anonymous Posted on Dec 06, 2017
Memory error I took many photos, and even previoulsy managed to successfully download them to my computer. A few days ago, I got a Memory Error message, and am now not able to see any of the photos I took. Can I somehow retrieve these photos, and how do I solve the Memory Error problem, to continue using the camera please? Thanks
5 Related Answers
Brault
Brault Kelpin
  • Posted on Jun 10, 2008
SOURCE: Memory card error
I have the same problem, just started this week. I've been using this camera for 4 years, over 8500 photos, with no problem like this...
Anonymous
  • Posted on Dec 26, 2008
SOURCE: error messages "cannot display image" or memory card error, etc.
Try a different SD card to start.
Anonymous
  • 58 Answers
  • Posted on Jan 21, 2009
SOURCE: my pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
Anonymous
  • 33 Answers
  • Posted on Feb 08, 2009
SOURCE: I continually get "Memory Card Error"
Try connect camera to computer and insert memorycard. If it still doesnt read memory card then its nothing u can do with this problem.
Take the camera back to the store for repair.
Anonymous
  • 8 Answers
  • Posted on Mar 18, 2009
SOURCE: Memory Card Error after Formating memory card
instead of quick format, use the full format.  Then put back in your camera and format again with the camera.
Top Pentax Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Frank Fernandez
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Pentax Camera Expert? Answer questions, earn points and help others
