Car Audio & Video Logo
A
Anonymous Posted on Oct 07, 2012
Why is the protection light coming on my Cadence Ultra Drive Q3000
We wiring up this amp, the protection light came on
1 Related Answer
Anonymous
  • 631 Answers
  • Posted on Dec 31, 2007
SOURCE: Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Top Cadence Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
