Frigidaire PLEFMZ99EC Electric Kitchen Range Logo
Posted on Feb 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code F20 pops up after turning on the burners. I have turned the breakers off and reset the clock numerous times and even unpluged the the cord and reset everything but nothing works. The appliance has been used maybe 4 times since i bought it new 2 years ago, 2nd home. Thanks
L Vincent Testa
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Frigidaire Master 724 Answers
  • Posted on Feb 16, 2018
L Vincent Testa
Frigidaire Master
Level 3:
Renaissance:
Answers
724
Questions
0
Helped
375099
Points
3088
An F20 or FH error code indicates a water supply problem. Here are some common issues:
  • Both hot and cold water must be connected and turned on
  • Water inlet hoses kinked
  • Water inlet valve screen clogged
  • Water pressure less than 10 psi
  • Not using HE High Efficiency detergent
  • Flood-preventing devices that shut off the water to the washer
Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both hot and cold water must be connected to the washer supply and turned on. The washer will not properly operate with only one incoming source of water. The water valve inside the machine needs to have the "pressure" from both attached hoses in order for the washer to complete the cycle.
If a cold water wash is selected, the washer is designed to add hot water to keep the temperature optimal for cold wash performance (75°F +/-10°).If you want to save energy by not connecting to the hot water line (or only have access to a cold water line if connected in a garage, etc.), purchase a "Y-connector" and an extra inlet hose to connect the hoses to both sides of the water valve.
NOTE: If you choose to connect only to cold water, wash performance may be affected.
Are the water inlet hoses kinked? Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged? Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent? Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Are you using flood-preventing devices that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
CLICK HERE for more information on use of flood safe devices
Removing the Error To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start.
NOTES:
On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
If the error remains on the display, and all of the other conditions above have been checked, call for service.
If you would like to download or view product literature for your appliance, please visit our Manuals and Literature page.
What is an F20 or FH Error Code on my Front load Washer
4 Related Answers
Anonymous
  • 135 Answers
  • Posted on Aug 09, 2007
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Jeffry's Appliance Service
  • 254 Answers
  • Posted on Jul 12, 2008
SOURCE: GE Spectra - burner pops & blows breaker
Either the burner has gone bad or the limiter on the burner.
Anonymous
  • Posted on Dec 17, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Anonymous
  • Posted on Sep 13, 2010
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
