SOURCE: My shredder stop shredding. has paper caught in itposted
If your equipment makes abnormal noise when you try to switch on again then gear problem is confirmed else the change over switch should be defective or there may be a open circuit in the change over switch connection I shall advice you to call the service engineer for fixing the problem else take safty pecaution to attempt repairs
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
SOURCE: when on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Well, the shredder will work but it has a grinding sound and it will take only a couple of inches of paper before it stops and I have to pull out and reinsert the paper. That is with no more than one or two sheets.
Another brand uses oil to lubricate the teeth and the gears. Would that help?
jenny
no auto-start, power on, feed paper, no stop after
there is paper stuck in the shredder and the reverse button is not working
I'm in the middle of shredding old phone bills, from the past 4 years. I was shredding 4 sheets of paper when suddenly, in the middle of that batch, the shredder just stopped. I tried to reverse it, but nothing happened. The paper is now stuck in the shredder, and there is no noise when I turn it on or when I try to reverse it. Nothing happens. I tried to get shreds out of the coils underneath, but that did not help, either.
squeaked and then stopped shredding
