Uniden BC92XLT Handheld Scanner Logo
Anonymous Posted on Jan 06, 2009
How do i program my scanner - Uniden BC92XLT Handheld Scanner
Jim
Level 1:
  • Contributor 31 Answers
  • Posted on Jan 07, 2009
Jim
Contributor
Level 1:
Answers
31
Questions
0
Helped
11687
Points
42
I need to know what part of programming do you need help with.
1. Finding Frequencies for agencies around you?
2. Actually puting the information into your scanner?
elijam1
http://www.scannermaster.com/?Click=37131
  • fuct_54 Aug 30, 2010
    I need to porgam a LS4208 to read code 93
Cannot get scanner programed
Most radio scanners these days have software that you can program from your PC etc, You will also need a cable, if not supplied. Check at the Uniden website. However you should be able to program it manually. Again the instructions that came with it? should tell you how.
Normally a scanner can be programed to scan between two frequencies ie 144 to 146 for the 2mtr amateur band etc
or you can program channels.
I cant Find A Programming Cable For My PC To Scanner
You do not ever need to program a scanner, and a scanner cannot program a PC. So why are you looking for a programming cable?
How do i program a apco 25 freq into the scanner
Just program a p-25 apco into a regular channel of your scanner... in your conventional scan mode...Just go to a certin channel of your scanner and program it in and it will automatically come in the APCO -P25...I have one of these scanners....ITs a wicked scanner...a good one...
3helpful
How do i program the bc350a scanner
Your scanner does not have a standard keyboard programming function. Rather you must "capture" a frequency in SCAN or SEARCH mode, and then transfer (program) it into the scanner's PRIVATE bank. For detailed instructions on doing this, you can download/print the scanner's operating manual here:
lhttp://www.uniden.com/pdf/BC350Aom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
3helpful
I have pro 135 from radio shack. How do I reset it and keep the channels that are programed in it?
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Power the scanner OFF.
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
I am trying to scan a document on the C7200. Last time I went somewhere on my computer, but can't find.
Try Control Panel, Printers and other hardware, Scanners and cameras..............or, your scanner program such as Scansoft or some other program that came with the computer or is available at the Scanner company website..........or, Scanner and camera wizard program in Accessories........or, free programs you can download like Open Office (a great program) or Picasa.
CanoScan Lide 25 scanner
Drivers and software are available at this link. Be sure and download and install both the driver and the Toolbox program (under Software)>
2answers
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Top Uniden Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
Frank Fernandez
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
