Sewing Machines Logo
Posted on Jan 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Presser foot lever does not lift presser foot
My singer sewing machine came to me from a friend.
It doesn't have a model number on it, neither does any of the accompanying literature... manuals, instruction sheets indicate what model it is, so I have had to enter a random model in the space below in order to submit this request for help!
It does have this printed on the manual: "5,8,10, 13 &22 Pattern Sewing Machines."
Here is the problem:
When I raise the presser foot lever the presser foot shank does not raise. The foot remains down.
I can lift the presser foot manually, however. When I do this the lever does not move.
I have the exact same problem as the person with the Singer, but I have an ancient Montgomery Ward sewing machine. I have oiled it everywhere I thought it needed, but will open it up and try it again. If that doesn't work, I suppose it will need to be serviced, and I'll let everyone know how that goes.
  • Anonymous Mar 29, 2014
    The sewing machine foot will not raise.
Rick
Level 2:
  • Expert 202 Answers
  • Posted on Jan 08, 2009
Rick
Expert
Level 2:
Answers
202
Questions
Helped
161673
Points
671
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
  • 2 more comments
  • rutonski Sep 17, 2010
    I can't find the screw!!!
  • Rick
    Rick Sep 17, 2010
    On every sewing machine presser foot bar there is a collar near the center of the bar. This collar has a screw in it to tighten it to the presser foot bar. The lifter hits this collar and raises the bar. If the screw is loose it will only raise the collar on the bar and not the bar. Maybe first you should reposition the collar (even loosen the screw to do so) and lower the collar down to the lifter lever. You will find the right spot so that when raising the lifter it will make contact with the collar with the screw in it and raise the presser foot bar. Pretty much the same on all sewing machines.
  • Rick
    Rick Sep 17, 2010
  • pilar
    pilar Apr 27, 2020
    I worked great thank you very much!
Robin Temple
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Dec 06, 2010
Robin Temple
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
21041
Points
It could be that yours is frozen like mine was. I followed the directions for resetting the screw, but it still wouldn't go. I had to sand off the rust and tap the end with a hammer! Now it goes up and down just fine! I have a Singer 9005, but like the techie said, they are all a lot a like in this part.
Top Sewing Machines Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Sewing Machine Expert? Answer questions, earn points and help others
